hesitating 95 2500 v8
Old Jun 7, 2013 | 07:28 AM
ChrisHamilton's Avatar
ChrisHamilton
Default hesitating 95 2500 v8
Ok so i start my truck everything is normal, but when i give it some gas, maybe 1500 rpms or better it will start hesitating like it needs more fuel, well i cant drive it down the road because i have no power and it doesnt want to go through an intersection, i cant floor it that doesnt solve anything, giving it less gas has the same effect as more so im more at loss of what to do right now. i thought it was a vacuum leak so i just went out and checked all the vacuum lines. bear in mind it has a new tps, and new fuel pump assembly
Old Jun 7, 2013 | 08:58 AM
Remove the front O2 sensor from the exhaust, see if it runs any better.
Old Jun 7, 2013 | 09:46 AM
ChrisHamilton
ok will try that later and post results
Old Jun 7, 2013 | 03:15 PM
ryan0714's Avatar
ryan0714
make sure u leave it connected.... just unscrew it from the exhaust
Old Jun 8, 2013 | 06:04 AM
ChrisHamilton
ok so i found my vacuum leak and found a new issue i wasnt aware of yet, it would appear the i have some popcorn sounds under my hood probalbly from the throttle body what would cause this?
Old Jun 9, 2013 | 11:39 AM
ChrisHamilton
ive found two rotting hoses that were cracked and have replaced both so ill see if that helps any i checked my cap and theres no obvious cracks in it just slight white oxydation on the points.
Old Jun 9, 2013 | 11:40 AM
ChrisHamilton
still unsure of the popping from under the hood?!!
Old Jun 9, 2013 | 11:49 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Any chance you have tried unscrewing the o2 as suggested?
Old Jun 9, 2013 | 02:50 PM
ryan0714's Avatar
ryan0714
popcorn sounds are normally spark knock (pre-detenation). that would be caused most likely from the plugs. might be due a tune up.
Old Jun 10, 2013 | 10:09 AM
ChrisHamilton
zman i havent had the chance its been raining here and i dont have a dry spot to get under it yet
ryan- i had just done a tune up, plugs,wires,cap,rotor button,coil, is it possible that a plug could be fouling and not working right
