Cam help
Old Jun 9, 2013 | 09:56 PM
Adobedude's Avatar
Adobedude
Originally Posted by wardom3232
Hmm I've heard of doing it but would I need a fresh motor to use them? Would the 4.56 gearing be good for my 35s?
I'm putting them on my 98 Ram, it has 130k miles on it, but it's getting some Mopar Magnum 1.92 heads w/ SS valves at the same time. The problem is the stock valve springs are barely good enough for a stock cam, the valve train is the weak link on a Magnum motor, that and the cracked heads
How many miles on your truck...?
Old Jun 9, 2013 | 09:58 PM
wardom3232's Avatar
wardom3232
And how much horsepower would thoughs add?
Old Jun 9, 2013 | 10:00 PM
wardom3232's Avatar
wardom3232
It's got 156,000 with about 1/3 plowing miles
Old Jun 9, 2013 | 10:12 PM
Adobedude's Avatar
Adobedude
No idea.....LOL
It's a sum of parts, my Ram gets my Dakota's hand me downs if they aren't too much. I use the Ram to tow the Dakota, so low end is a gotta have and since I don't want to tow with the OD on I have 3.55 gears, low end has to come from the motor.
If you pan on doing anything, I'd at least get NEW stock valve springs, the problem is they are beehive and no one makes a simple drop in replacement...You have to get new springs and matching retainers or get some EQ heads already built with new springs ...Maybe someone will chime in on after market Magnum heads...I have Eddys on the Dakota and a couple pair of Magnum RT heads so I don't pay attention to heads...I don't need anymore.
Old Jun 9, 2013 | 10:41 PM
spun360's Avatar
spun360
iron ram EQs are good heads! thats what i have. out of the box they handle 1/2 inch lift for about $800 a pair.
Old Jun 9, 2013 | 10:45 PM
beeker's Avatar
beeker
Just keep in mind it's a Magnum motor not a Hemi. These motors come under powered from the factory, only 230hp, add into the mix your mileage and 4x4 drive train, now you're seeing more like 200hp at the wheels. Adding gears, heads, cam, intake, TB, tuning, roller rockers, rough guess would put you at 250 to 280hp. You still want more hp? how bout boring out and stroking to 408 or even 426... we're talking serious time and money.
Old Jun 10, 2013 | 07:07 AM
redneck_ram's Avatar
redneck_ram
comp cams 20-745-9 is the cam i have. its an extremely torquey cam. i also have this cam pair with the harland sharp 1.7 non-adjustable roller rockers.
i have stock sized stainless one piece valves, with some minimal porting.
50mm throttle body, mopar m1 intake manifold, and longtube headers going out to a 3" single exhaust.
3.55 gears, and 33's this truck MOVES!
Old Jun 10, 2013 | 09:47 AM
Adobedude's Avatar
Adobedude
What length push rods?
Old Jun 10, 2013 | 11:55 AM
spun360's Avatar
spun360
i assume after market parts are meant for a direct replacement with out screwing up the rocker geometry. you know how that goes, dont count on it!
i have the 20-745-9 cam also! EQ heads, and hughes mini shaft 1555 alu roller rockers. from what i know about setting the magnums up- the stock p-rods are 6:92 long. when i measured for 1 piece rods, i expected to be way shorter than stock! i came up with 6:90 and had plenty of adjustment on the roller rockers. it sometimes depends on the head gasket squish also! lots of factors depend on the p-rod length.
Old Jun 10, 2013 | 07:36 PM
redneck_ram
stock i think. theyre mopar performance hardened push rods. i have zero problems with them.
how do you like your setup so far?
