98 ram 1500
Old Jun 9, 2013 | 05:32 PM
jcaudill28's Avatar
jcaudill28
Default 98 ram 1500
constant grinding or metal growl sound while driving.any speed.forward and reverse.drive shaft has been repaired and new brakes all way around.any suggestions to the rear end that could be bad..no signs of any fluid leakage.
Old Jun 9, 2013 | 05:35 PM
Bad bearing. Need to find it.
Old Jun 9, 2013 | 05:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Add ALL the info about your truck to your sig and profile. Thanks
Noise coming from front , rear, middle? Is it a 4x4 or 2wd? Need more info, add it like I suggested.
Old Jun 9, 2013 | 05:42 PM
jcaudill28's Avatar
jcaudill28
im new to working with differentials.other than taking the yoke out of the diff.and checking that 1.where else are there bearing in the diff.
Old Jun 9, 2013 | 05:56 PM
jcaudill28's Avatar
jcaudill28
noise is coming from rear
Old Jun 9, 2013 | 06:02 PM
zman17's Avatar
zman17
1988? Anyway, 2wd. Could be diff or could be axle bearings. You'll need to check. Download a service manual from the FAQ/DIY section and get a Haynes manual also. You need to raise the rear of the truck off the ground and figure it out.
