Exhaust set up
Old Jun 10, 2013 | 11:33 PM
Dillon555mil's Avatar
Dillon555mil
Default Exhaust set up
Hi just wondering what all I need for the exhaust set up I want. I am ordering pace setter long tube headers part no 70-2213. The truck is a 1997 Ram SS/T, and the check engine code is being thrown for the cat. So, if I delete cats with the long tube headers do I need like an O2 sensor extension? Or is there a port already in the headers? LOL. Also after that should I get a Y-pipe? I want to go out each side in front of the reaR wheels. So what exhaust should I order or should I just go straight pipes? I'm in Canada BTW, so no emissions. Thanks
Last edited by jkeaton; Jun 10, 2013 at 11:44 PM. Reason: No caps, no punctuations......canadians....eh!
Old Jun 11, 2013 | 09:16 AM
SilverSS's Avatar
SilverSS
Looking at pics of the headers it looks like there's an O2 bung in the pass side header. Not sure if you'll need an extension or not. I think there's an O2 sensor for our trucks that has a longer harness on it. I would just run true duals off the longtubes instead of messing with a Y pipe. Find a local shop to do it for you. I would keep the rear O2 and just put a spark plug non fouler in the rear to get rid of the check engine light. If you just leave the sensor disconnected the cel will stay on. I would also recommend mufflers. I have stock manifolds, true duals, and 12" glasspacks and it is LOUD. If it was my daily driver I would have to quiet it down some because I would feel bad starting it up at 0630 am to go to work lol.
Old Jun 11, 2013 | 01:02 PM
Johnn123's Avatar
Johnn123
There is a reason your cat went, most likely this. I would check that first and if necasarry fix it before delving into a new exhaust. Where in Canada? If your in Ontario yes there is and its a fineable offense to not have a cat.
