axle interchangability Q:
Old Dec 28, 2013 | 09:45 AM
northamerican's Avatar
northamerican
So still running my rig in 2wd, cause Im a cheap bast%$d and am waiting for a cheap front diff to come available. Can a set of front and rears with 4.10:1 gearing from a gas 3/4 ton ram be swapped in? how will that effect the drivabillity of my stock Ram 2500 cummins, keeping in mind I tow heavy trailers in the summer months. All trucks involved are year 2000.
Old Dec 28, 2013 | 09:51 AM
D60 isn't as heavy duty as the rear you currently have. (which is probably a D70, unless you have a manual trans, then it is a D80) Aside from that, would probably bolt right in.
Your front is a D60 in any case, so that would be an easy swap.
Old Dec 28, 2013 | 10:01 AM
northamerican
I was mainly wondering about going from 3.55:1 to 4.10:1. how will that affect my truck?
Old Dec 28, 2013 | 10:26 AM
Ham Bone's Avatar
Ham Bone
It will help you when you tow. And won't affect drivability too much.
Your revs will be a little higher than factory, more noticeable at highway speeds
Old Dec 28, 2013 | 10:45 AM
northamerican
wont damage or prematurly wear my tranny or anything? or set of any trouble codes?
Old Dec 28, 2013 | 10:57 AM
stewie01's Avatar
stewie01
Nope.
You might be a slight mileage decrease if you frequent the interstate, but nothing major...
Old Dec 28, 2013 | 11:14 AM
northamerican
ok, thanks guys
Old Dec 28, 2013 | 11:20 AM
Arde's Avatar
Arde
Actually, the lower gears will be better on the trans.
Old Dec 28, 2013 | 11:38 AM
northamerican
nice, .....
