Wacky Vents/ compile info trying to figure it out
The check valve maintains a vacuum in the lines when there is a low vacuum condition in the manifold/keg.
The vacuum resistor will extend the period of time that the systems will continue operate under the low vacuum condition... it should also make it slightly more tolerant of minor leaks.
