Transmission Cooler
Add a extra capacity transmission pan for starters. I did this while using the stock Tow package cooler and my trans. temps have never went over 165 degrees on hot miserable days towing a horse trailer with 2 horses and a 30 mph sidewind.
True, it is enough.
Yea I have the the extra big pan. My 8000 lbs travel trailer got her up a bit past 190 yesterday... I think she needs a bit more... Thank you Arde!
Trending Topics
all ways use high pressure hose. any good REAL parts house can get it for you. but steel tubing is better. do NOT use any thing else, ie copper and so no. the factory used steel for a reason. here is an external fluid filter. heres a paste sorry, live with it.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com.au/magna-fine.html*
2. for other sizes wix 58964 5/16 tube size reff:http://www.wixfilters.com/filterlook...sionfilter.asp
https://dodgeforum.com/forum/2nd-gen...ter-added.html
