A/C System Diagnosis
Old Jun 28, 2013 | 11:03 AM
SparkMasterB's Avatar
SparkMasterB
Default [SOLVED] A/C System Diagnosis - Didn't have relay plugged in.
EDIT: DERP. Totally forgot I removed the A/C relay so the compressor would not turn on with the system empty.... I'm still going to replace the accum though. Verified it's a good idea to replace it.
This sub forum seems to get more action than the Tech Help forum so I'm posting this here. I've got an issue with my A/C.
My A/C system has been empty since the winter (everything hooked up, just not charged).
Today I went to charge it and ran into a problem. It holds 28-29 inches of vacuum just fine. I let it sit for about 35-40 minutes and the needle didn't budge, so no leaks. As soon as I opened the valve for the first 12 oz. can low and high pressure went to 70PSI. Its as if the lines were clogged.
I think that since it was sitting the accumulator is bad. IIRC I was told that if an A/C system sits unused for a while its a good idea to replace the accumulator.
I released some pressure (down to 50psi) and still no go. The compressor will not kick on. It worked fine last fall before I had the system emptied.
What is wrong? Compressor? Accumulator? If the compressor isn't turning on, can I jumper the connections to get the compressor to switch on?
Old Jun 29, 2013 | 07:04 PM
ryan0714's Avatar
ryan0714
i think that the orifice tube would clog before the other parts going bad man. its a part that literally sits right inside you low pressure line. most the time it will be right where it connects to the accumulator. sometimes they put it down by the condensor. its the most commmon thing to clog.
