96 1500 5.2 knocking
Old Jul 1, 2013 | 03:43 AM
AJAF07's Avatar
AJAF07
Default 96 1500 5.2 knocking
Hello gents, I'm back with more issues with the beast. When I try to start the truck, it's starts, there is loud knocking and then it quickly shuts off. I took it in and they told me it was the main bearing, which I don't believe to be the issue at all, any advice?
Old Jul 1, 2013 | 07:06 AM
dhvaughan's Avatar
dhvaughan
knocking from the lower part of the engine is usually a main crank bearing or rod bearing, or broken rod or piston. why do you think its not that?
you can remove the oil pan and turn the engine by hand to see what's hitting.
Old Jul 1, 2013 | 08:18 PM
AJAF07's Avatar
AJAF07
But why would that cause the engine to shut off? Is it the knock sensor?
Old Jul 1, 2013 | 08:27 PM
Ham Bone's Avatar
Ham Bone
These trucks don't have a knock sensor
Old Jul 2, 2013 | 10:48 AM
More than one problem going on there.
Old Jul 2, 2013 | 06:35 PM
dhvaughan's Avatar
dhvaughan
i don't know. could be any of a million reasons-
compression problem.
lack of fuel.
coolant leak into cylinder.
moving parts of the engine binding up.
i'd say that it shutting off is secondary to it knocking.
find out what the knock is before worrying about anything else.
Old Jul 2, 2013 | 07:00 PM
AJAF07's Avatar
AJAF07
Good call my friend
Old Jul 2, 2013 | 07:01 PM
AJAF07's Avatar
AJAF07
I might end up taking it to the dealership, all the other shops are run by retards around here that charge me for engine tear down, but don't tear down the engine.
Old Jul 2, 2013 | 08:54 PM
dhvaughan's Avatar
dhvaughan
you are likely to get screwed over in a bigger way by the stealer.
Old Jul 3, 2013 | 02:58 PM
BrandonBuc'em's Avatar
BrandonBuc'em
sounds like a good time to swap out for a cummins to me these trucks are pretty easy to work on, ive done everything myself since i got it...well with the help of this forum of course. good luck with your truck buddy
