ABS light and Brake light sometimes on
Old Jul 3, 2013 | 05:40 PM
truck42's Avatar
truck42
Default ABS light and Brake light sometimes on
99 Dodge Ram 3500 4x4 duelly, the abs and brake light are coming on and off a lot. I have replaced the rear abs sensor and that did not fix it. The abs is also kicking in once in awhile when I brake (little scary to drive). My speedo works fine. I even jacked up the rearend and tryed to see if it went away. Nope. Seems when I idle the light goes off. Pushing the brake or putting in gear comes on. And it goes off and on when driving?
Any advice?
Truck
Old Jul 3, 2013 | 07:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the brake line running along side the fuel tank. common prob. All it takes is a small pinhole.
Old Jul 3, 2013 | 08:51 PM
truck42's Avatar
truck42
i replaced that line last year. and my fluid level is not low.
Old Jul 4, 2013 | 12:31 AM
Matt Nickerson's Avatar
Matt Nickerson
Do ya got 4 wheel abs? If so check the front hub units for play.
Old Jul 4, 2013 | 06:33 PM
truck42's Avatar
truck42
No play, just replaced Dr side last year.
Yes 4 wheel abs
Old Jul 4, 2013 | 09:22 PM
Then you need to take it to a shop to get the codes read, unless you have a scanner that can do it. The hand held guys and the ones the parts stores have generally can't.
With 4wal, there is a LOT more for the computer to whine about, and rather than throwing parts at it ***** nilly, you need to know what the computer thinks is wrong, and start looking there.
Old Jul 5, 2013 | 01:00 PM
truck42's Avatar
truck42
everybodys closed for the holiday weekend will try monday to have it read. thanks
