Exhaust manifold bolts
So, I'm replacing the exhaust manifold gasket on the passenger side. On one of the center connections, the bolt unscrewed off of the stud that goes into the block. On the connection right next to it, the entire stud unscrewed from the block.
With the stud still in place, I can't pull the gasket on or off, and am unable to pull the manifold out far enough to clear the stud.
Do I need to remove this stud, or do I need to loosen an exhaust connection further down, to allow me to pull it over?
Thanks,
Thanks,
Pretty common for the studs to come all the way out of the head upon removal. If you have all of the nuts/bolts loose from the manifold and the pipe unbolted (and pulled away) from the bottom of the manifold (loosen the lower manifold bolts on both sides where the Y-pipe connects to make the job easy), there should be plenty of room to remove the manifold, even with the stud still in the head in the center.
