OBDI tuning
The mopar performance PCM has a disclaimer that says not for use in towing applications I am guessing because of the timing advance and the timing curve that's programmed into it. I am going to give it a few more days and see what the computer is going to learn on its on. I will update in a couple of days with results. Not too crazy about a carb. Is there a way to do a carb but still keep my on board diagnostics to blink codes and stuff out.
How is the mopar computer going to perform with the initial advance in the timing already ground into the cam? I always run premium feul already. I have never heard the valves pinging which further adds to my suspicion of the dealership doing the death flash on the computer without telling the previous owner which was my stepfather who bought the truck new.
if you can find a Mopar Perf PCM that would be your best bet, and second would be MegaSquirt, if you are interested in that PM me and I will give you some pointers about that...
It's not a good idea to have a OBD1 PCM "reflashed", half of the time it ends up frying the PCM...
OBD2 started in late model 1996 trucks. Early model 1996 trucks still had OBD1. Granted, that some of the early late models (like mine) had a OBD1/OBD2 mix, it really was a OBD1 computer with a OBD2 interface...
There is a right way to tune OBD1 Mopar PCMs (not perf pcms), but it requires the PCM to be disassembled, and the ROM to be hooked up via serial port, a extensive procedure...
Yes, the early JTEC computer didn't support that, so most 1997 PCMs didn't have it yet either, it primarily came along with the 1998.5 change, when they also introduced the new PCM. As far as tuning it goes, the 1998.5+ PCM is the easiest and allows the most options, some guys I know actually converted a 96 to aa 98.5PCM, it did work, and they were able to finally tune it...
If your interior looks like the above, then you are a 98.5 (if gasser, of course).
If it looks like below, you are not.
What will the sticker say that I am looking for?
I'm fully familiar with the differences between 97 and 98's, but considering Dodge introduced the Quad Cab in 98 along with a new interior, I don't see why they would have had two interiors for the same year.
And my door panels are different. Round speaker hole, not squaretriangle-ish.
