A/C (still) not working after replacing condenser and charging w/ freon
Old Jul 13, 2013 | 11:59 PM
Willster's Avatar
Willster
Default A/C (still) not working after replacing condenser and charging w/ freon
I replaced my condenser this afternoon and charged the A/C with freon, but it is still not blowing cold air. It is not leaking anywhere that I can see, and I hear the compressor kick on frequently, but the air does not get cold. Any ideas or suggestions what I should check or do next? Thanks in advance....
Old Jul 14, 2013 | 12:58 AM
TiminSoCal's Avatar
TiminSoCal
I think after opening the system (replacing parts)
you need to pull a vacuum on it before adding freon.
Too much or too little freon will also affect the temp.
Someone else will correct me if I'm wrong.
Old Jul 14, 2013 | 07:51 AM
Tim is correct. Need to completely evacuate the system before recharging.
Old Jul 14, 2013 | 10:19 AM
Arde's Avatar
Arde
^^+1 on the above...It cycles off and on because you're low on freon.
Old Jul 14, 2013 | 12:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+3.... and how much R134a did you put in? Also needs the correct amount of PAG oil when any component of the system is replaced. AC is generally not a diy when it comes to charging the system, unless you have the right equipment and know how.
Old Jul 14, 2013 | 10:15 PM
Willster's Avatar
Willster
Thanks, guys. I used one bottle of R134a freon I bought at O'Reilly, mainly just hoping that was all I would have to do after replacing the condenser was spray the freon in and have cold air for $20, but I had a feeling I would probably need to take it to an A/C shop and pay the $100-$150 to have it fully serviced (evacuated then filled). So I will do that. One good thing though, I have no leaks from the lines going to the condenser, and I did before changing it, so that's good so far I guess :-)
Old Dec 12, 2013 | 10:10 AM
Willster's Avatar
Willster
A/C works now! (Not like I need it right now, it is 10 degrees outside lol). Got a new condenser as a bonus when the tranny was rebuilt; when they replaced the cooler, they somehow poked a hole in my condenser (yea, not sure how that happens, but it did), so they put a brand new condenser on and charged the A/C for no extra charge. So I'm ready for summer!!!!!
