2001 Ram slow to start
Old Aug 9, 2013 | 12:31 AM
  #41
eddiekimberly's Avatar
eddiekimberly
Originally Posted by Paul DeHayes
When you did the plenum, did you replace the actual plate as well, or did you just replace the gasket? That's a stamped steel plate on the bottom of an aluminum intake, and it'll eventually happen again if you didn't opt for the aluminum plate, due to the differing expansion/contraction rates of both metals (just a thought).
Sorry, should have been more clear. I did the Hughes kit, along with new distributor, rotor and thermostat. I TRY not to half-*** anything.
Old Aug 9, 2013 | 01:33 AM
  #42
eddiekimberly
Also, COULD the IAC being dirty cause my slow start? I haven't had time to look at it yet
Old Aug 9, 2013 | 08:12 AM
  #43
Possible... but, if once it starts, it idles fine, probably not the issue.
How is your fuel pressure? Is it hard to start all the time, or just first start of the day/after it sits for a while?
Old Aug 9, 2013 | 12:41 PM
  #44
eddiekimberly
Happens randomly. Sometimes, it starts fine, sometimes it turns over a handful of times before it fires up. This is gonna drive me ape****.
Old Aug 9, 2013 | 12:44 PM
  #45
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
But have you checked fuel pressure?
Old Aug 9, 2013 | 12:52 PM
  #46
eddiekimberly
yes. 50psi. just installed a new fuel pump a month ago... entire new unit.
Old Aug 9, 2013 | 01:05 PM
  #47
zman17's Avatar
zman17
Retired Moderator - RIP
Does the pressure hold when the engine is turned off?
Old Aug 9, 2013 | 01:10 PM
  #48
eddiekimberly
Timed it for 5 minutes (actually about 5 1/2 minutes) and it dropped 1psi. Let me amend this. When the key was switched off, it dropped from 50 to 43, which I attributed to just the pump shutting off, then over the next 5+ minutes, it lost 1psi
Old Aug 9, 2013 | 01:33 PM
  #49
zman17's Avatar
zman17
That ok then. What about engine coolant temp sensor? Without reading back in the thread(prolly was suggested already).
Old Aug 9, 2013 | 01:41 PM
  #50
eddiekimberly
Quick run through... new Hughes kit, distributor, rotor, coolant temp sensor, fuel pump assy, and thermostat, since I was already doing the plenum.
