What's leaking?
Old Jul 22, 2013 | 03:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Arde
You might want to consider changing both seals, they're cheap, and you're already there.
+1... you beat me to it.
Old Jul 22, 2013 | 05:31 PM
diverjer's Avatar
diverjer
TC use the same as transmission, ATF+4?
Old Jul 22, 2013 | 06:12 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Yep yep.
Old Jul 22, 2013 | 07:29 PM
dhvaughan's Avatar
dhvaughan
here's what the rear end of the transmission looks like.
Old Jul 23, 2013 | 07:39 PM
diverjer's Avatar
diverjer
I think I will change TC fluid, took off skid plate, will got get ATF+4 tomorrow. That is a big bolt, I had 1 1/8 socket, too small, 1 1/4 was too big. Must be 1 3/16. Had open end wrenches all around, even a 1 7/17, but no 1 3/16. Oh well big crescent works. Looks like it was made 6/3/96 and is a 231 that holds 2 1/2 pints.
Old Jul 23, 2013 | 07:41 PM
dodge dude94
I don't remember what size the bolt is. Took my skid without much trouble. Or are you talking about the fill bolts? Some trucks have allen key others have hex bolt...
Old Jul 23, 2013 | 07:44 PM
diverjer's Avatar
diverjer
I meant the fill and drain.
Old Jul 23, 2013 | 08:05 PM
dhvaughan's Avatar
dhvaughan
my 01 fill and drain plugs are inside hex (allen), size=10mm not 3/8 which is just close enough to strip it out.
Old Jul 23, 2013 | 08:34 PM
Arde's Avatar
Arde
Remove the fill plug first, then the drain plug. Someone on here removed his drain plug and then couldn't get the fill plug out. Left him up that proverbial creek without a paddle.
Old Jul 23, 2013 | 09:10 PM
diverjer's Avatar
diverjer
That is a good idea. I already put a big crescent wrench and loosened both and re tighten. Just wanted to make sure I couldget the big wrench in there. No allen wrench, just a really large plug.
