What's leaking?
Old Jul 20, 2013 | 03:30 PM
Annihilator_X9's Avatar
Annihilator_X9
Default What's leaking?
I'm assuming it's the rear seal on my transmission, or is it the transfer case? And do they share the same fluid? Not very knowledgable on 4x4 systems yet.
Old Jul 20, 2013 | 03:38 PM
dhvaughan's Avatar
dhvaughan
the fluid is red, so its ATF, but you're correct that both the AT and TC use ATF. so its either the rear seal of the AT or the front seal of the TC. the TC only holds about 1 quart of fluid, so check and see if its low. you're leaking a lot. don't let the TC get low and run out or it'll burn it up in a hurry.
if nothing is obvious, you could put some ultraviolet oil dye in the TC.
Old Jul 20, 2013 | 03:40 PM
Annihilator_X9
Well, I'm pretty sure it's the trans then because I just added a quart to it since it was low and it started leaking worse as soon as it was full again.
And so the fun begins.
Old Jul 20, 2013 | 03:41 PM
Annihilator_X9
Also, thanks! You validated what I originally thought.
Old Jul 20, 2013 | 07:42 PM
dhvaughan's Avatar
dhvaughan
if you haven't done so, download the service manual for the 01. it has good diagrams of the transmission.
this is a question - if you drop the tcase, does the transmission have an easy to get to rear seal? or do you have to take the damn transmission apart?
Old Jul 20, 2013 | 09:35 PM
Annihilator_X9
I have no idea. I've never dropped this tranny. I had the front seal of the tranny replaced a couple years ago but I didn't do it.
Old Jul 21, 2013 | 09:26 AM
Apparently, the seal can be changed without yanking the trans. Drop the t-case, and there it is..... manual suggests slide hammer with a screw... (screw it into the old seal, and give it a couple whacks.) New seal is just driven in.
Old Jul 21, 2013 | 10:59 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sheriff420 has a DIY in the DIY/FAQ section. And yes, it's the transmission as you've already found out. I went through this like 2 years ago.
Old Jul 22, 2013 | 02:27 PM
Annihilator_X9
Sweet. That'll save a chunk of change if I can tackle this myself.
Old Jul 22, 2013 | 02:44 PM
Arde's Avatar
Arde
You might want to consider changing both seals, they're cheap, and you're already there.
