shift selenoid and pressure change out
Old Jul 26, 2013 | 07:41 PM
sidewayzz's Avatar
sidewayzz
Default shift selenoid and pressure change out
01 5.9 auto 142,000 miles. Truck started going to 3000 before it would upshift from 1st to 2nd then to about 3500 before it would shift again. Changed out the selenoid to a borg and pressure sensor. This didnt help anything. The pan magnet was very clean. Didnt see any loose connections. The truck is throwing no codes. Did I overlook something? Check fluid level and its good. This just started all of a sudden. Any help would, I would be thankful. I am thinking rebuild time. one more thing when its around 45mpg after the shift it gets real eratic. This is even with OD turned off or on. I also checked the cable at throttle body and its good. Thanks.
Old Jul 26, 2013 | 09:53 PM
did you just change the solenoid? Or did you change the pressure sensor as well?
Old Jul 26, 2013 | 11:01 PM
sidewayzz's Avatar
sidewayzz
i changed both. I got them off ebay from electrical advantage. I wonder if I installed them wrong
Old Jul 26, 2013 | 11:02 PM
stewie01's Avatar
stewie01
I'm not sure it's possible to install them wrong.
You might check the TV Cable, it may need adjustment.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Old Jul 26, 2013 | 11:08 PM
sidewayzz's Avatar
sidewayzz
I will check TV adjustment tomorrow.Thanks
Old Jul 27, 2013 | 07:42 AM
Recheck fluid level as well. (in neutral) Take a look at the connectors on the PCM too, they like to corrode, and then strange things start happening. (disconnect battery first. )
Old Jul 27, 2013 | 08:19 AM
sidewayzz's Avatar
sidewayzz
done all that this morning. still same. I am wondering if that china made pressure sensor could be bad.I am fixing to put old one back in.
Old Jul 27, 2013 | 09:04 AM
dhvaughan's Avatar
dhvaughan
does the truck act differently with new pressure sensor or is it the exact same as the original. if same as the original, then its unlikely that its bad.
Old Jul 27, 2013 | 09:47 AM
sidewayzz's Avatar
sidewayzz
acts the same. I have been reading that some of them china parts have been known to be bad out of the box. I cant find anything else wrong. I have checked all the above. Guess I am just shooting in the dark here.2
Old Jul 27, 2013 | 10:03 AM
stewie01's Avatar
stewie01
Band adjustment?
Could just be the beginning of transmission failure
