I need a fuel rail and a wiring harness
Old Aug 2, 2013 | 10:44 AM
Novarider's Avatar
Novarider
Default I need a fuel rail and a wiring harness
My truck recently had an engine fire because of a split fuel rail. I need a replacement fuel rail and a wiring harness. Does anyone have a fuel rail and wiring harness that will be direct replacements for my truck?
My local junkyard doesn't have them.
Old Aug 2, 2013 | 01:41 PM
I might have a fuel rail... but, it's off a 95, so, not sure if it is the same. Harness certainly won't work.
Old Aug 2, 2013 | 07:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Call these people, they are great. http://www.mintonmotorsinc.com/index.html
Old Aug 3, 2013 | 01:06 AM
Gaius's Avatar
Gaius
You can clamp fuel injection hose on the crossover piece. If not, just go to a yard and get one from a Durango or and Cherokee. Just make sure it's a 96+ so you don't get one with a pressure regulator on it.
You'll likely have to get a Ram harness though, the Jeep one is definitely different. The Dakota/Durango one might be the same, but I can't verify.
Old Aug 15, 2013 | 02:46 PM
Novarider's Avatar
Novarider
I called them and they won'y sell me either part. The man on the phone said he only sells whole engines.
The fsm says the rail is non repairable. I don't want to risk another fire. My wife was lucky it happened when other people(including a retired fire fighter) were around. I don't want to press my luck.
Old Aug 15, 2013 | 03:13 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If the parts from a 1997 5.2L 1500 will fit, hit me up. I have all of those parts and can supply pictures.
Old Aug 15, 2013 | 03:25 PM
Novarider's Avatar
Novarider
I don't know if the harness will fit. Hopefully someone here knows?
Old Aug 15, 2013 | 03:38 PM
97 harness won't work. Too many changes after 98.
Old Aug 15, 2013 | 04:09 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
What about the fuel rail?
Old Aug 15, 2013 | 05:18 PM
zman17's Avatar
zman17
Is your fuel rail black plastic or a steel one with a test port?
