Need help! Abs;brake light!!
Old Aug 2, 2013 | 05:43 PM
justinr678's Avatar
justinr678
Angry Need help! Abs;brake light!!
I have a 98 2nd gen 182k miles, Now I've done everything i can to try to fix these lights, With no luck. New brakes, drums ABS sensor the whole 9 yards. Yet both these lights will not go off. I've even got a new computer and harness for the truck and still no luck. It's not even throwing a code! please help!
Old Aug 2, 2013 | 06:54 PM
dhvaughan's Avatar
dhvaughan
welcome to df.
did you replace speed sensor in the tail housing of the transmission?
do a search here for "speed sensor". see how many people benefit from that.
Old Aug 2, 2013 | 08:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If the ABS and brake lights are on, it is throwing a code. Problem is, you need a scanner capable of reading ABS codes. Other than that, I'd say you have a pin hole in the brake line that's next to the gas tank.
Old Aug 2, 2013 | 09:01 PM
justinr678's Avatar
justinr678
Brake line's have no leaks. And yes I've replaced the speed sensor. I'm out of ideas here.
Old Aug 2, 2013 | 09:33 PM
You need to take it somewhere that can read ABS codes. The little hand held fellers just won't cut it. I don't think the parts store readers will either. Need to take it into a shop, have them plug in, and see what it has to say.
Old Aug 3, 2013 | 06:26 PM
atc250r's Avatar
atc250r
I had the same problem and it turned out to be a cracked harness connector located on top of the rear differential.
