'95 RAM 1500 very low mpg
Old Aug 5, 2013 | 02:50 PM
rayd341's Avatar
rayd341
Default '95 RAM 1500 very low mpg
Hello. I have a 1995 Dodge Ram 1500. 5.2 engine. All of a sudden I am getting only between 4 to 7 mpg (was 12 to 15 mpg last week). I have checked for OBD codes and they are: 12, 51, 32, 55. I have replaced the O2 sensor(Bosch) and EGR within the last 12,000 miles. Neither is OEM. I was told by Dodge techs, 12,000 miles ago, that the non OEM O2 sensor was an issue. Is there an issue that these two codes, 51 and 32, together indicate?
208,000 miles on the odometer.
5.2 Gas.
RWD
Thanks
Old Aug 5, 2013 | 02:58 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
These trucks usually hate Bosch O2 sensors.
I'd wager that that's part of the issue.
Old Aug 5, 2013 | 03:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
read the plenum sticky.
Old Aug 5, 2013 | 03:12 PM
Johnn123's Avatar
Johnn123
^^ +1 to both, most likely the issues.
Old Aug 5, 2013 | 03:18 PM
KasperR34's Avatar
KasperR34
Old Aug 5, 2013 | 09:07 PM
ReadRam's Avatar
ReadRam
Lose the bosch 02. Check for vacuum leaks, extra air entering the mix. Hole in your tank?
Friends siphoning gas while your asleep? Blown plenum is internal vac leak and I don't think that could account for such a sudden drastic change in mileage. Can really burn some oil though. What are your codes? Not everyone has them memorized.
Old Aug 5, 2013 | 09:14 PM
dhvaughan's Avatar
dhvaughan
mpg that bad means your really dumping gas.
either O2 sensor is calling for more more more or maybe a leaking injector.
pull the plugs and see if any one is worse than the others.
Old Aug 5, 2013 | 10:15 PM
Or a failed temp sensor......
