94 ram 1500 not shifting into overdrive
Old Aug 8, 2013 | 11:03 PM
wishihadachevy's Avatar
wishihadachevy
Default 94 ram 1500 not shifting into overdrive
Alright.... I have a 94 dodge ram 1500 4x4 5.9 with a 46rh trans that is not shifting into overdrive.... so far I have put a new temp sensor,had the overdrive rebuilt,checked the continuity on the wires going from the computer to the overdrive solenoid to make sure there is not a short in the wires, replaced the computer, and still no overdrive!!!
Any ideas? The only think I can think of to do now is to replace the overdrive solenoid but I was wondering if there is a full proof way of checking/testing the overdrive solenoid to know weather or not it was bad before I put any more money in the wrong places.... getting kinda tired of sinking money in it and nothing getting fixed.... any help would be appreciated.. and could it be something other than the solenoid?
Old Aug 9, 2013 | 08:19 AM
Need to know if the PCM is actually commanding O/D..... simple test, fun to set up for though. PCM simply grounds a wire to complete the circuit for the O/D solenoid. Stick a test light on that wire, (someplace you can see it....) and go for a drive. If the light comes on, but you don't get O/D, solenoid is bad. If the light DOESN'T come on, need to find out why the PCM doesn't want to engage it.
Does your speedo work? CEL on? Any codes?? Do you get TCC engage?
Old Aug 9, 2013 | 02:55 PM
wishihadachevy
Speedo works and t/c locks like its supposed to, no codes since I just replaced the computer and not sure what "CEL on" means?
Old Aug 9, 2013 | 02:59 PM
wishihadachevy
It was pulling a code before I changed the computer but I don't remember what it was for I think it was for a egr or something....
Old Aug 9, 2013 | 03:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
CEL = check engine light
Old Aug 9, 2013 | 06:02 PM
wishihadachevy
Well now I feel dumb...lol.. thanks for the definition.... not up to date with the automotive text lingo yet..
Old Aug 9, 2013 | 08:56 PM
[bestyodavoice] You will be..... You will be..... [/bestyodavoice]
Hang out here long enough, and you will learn all sorts of new acronyms. In fact, you will be qualified to become a member of NASA. (national acronym society of america.)
Old Aug 10, 2013 | 02:41 AM
UnregisteredUser's Avatar
UnregisteredUser
That why we troubleshoot rather than shotgun, friend.
Get the factory service manual. Start on page 21-578 if it's the 2001 FSM. There ya go.
