transmission problems
Old Aug 9, 2013 | 08:44 AM
bd2dabn's Avatar
bd2dabn
Default transmission problems
Hopefully someone can shed some light on my truck problem!
I was headed to work this morning going 65mph when the truck stopped pulling and started to rev up. I got it off the highway and into a parking lot. It will go into reverse and park, and will go into gear and drive but I think it is in the "limp" mode and will not go into 3rd or od. I drove it home on the side roads. I was wondering if the rain/moisture would possibly cause it since it was raining and I had driven thru a shallow puddle about 2 min before this happened? The truck has 205,000 miles on it and has been working fine until now.
1998 4x4 1500 extended cab
Old Aug 9, 2013 | 09:14 AM
Moved this to the correct forum.
Is your check engine lite on? Are there any codes? Sounds like O/D is slipping.... how many miles on the trans?
Old Aug 9, 2013 | 09:19 AM
bd2dabn's Avatar
bd2dabn
No trouble lights and haven't had time to check the codes yet.
Old Aug 9, 2013 | 02:47 PM
They can be had dirt cheap at most any parts store. Can check codes while you are there.
Welcome to DF!
