Multiple Cylinder Misfire - Need Help
Checked #5 and #8 plugs have pic below. found a little fuel on #8 but nothing major, checked spark on both cylinders with spark tester and have spark jumping 0.50" gap (plugs set at 0.40") so I've got good spark. Pulled Front O2 sensor, no change aside from noise level which was expected. only thing that has changed since doing IAC change is truck is now idling around 1,000 to 1,100 rpms, which is where it's always ran at since we bought it, but still idles rough.
Have to take a break and go to my sons school orientation. Gonna pick up new IAC while I'm out then check it out. I'll try driving without o2 sensor this evening if I have time. if not will let wife drive it monday and see what happens. If the misfire comes back, then I'll drive it Tuesday (my day off) without o2 sensor. Don't think it's a cracked head, oil looks good, and not consuming any coolant, and no smoke out exhaust.
And yeah the no money thing sucks....selling my truck because I just got a job after a month of unemployment and its a 30 mile round trip drive.....about $120/week in fuel. need something more fuel efficient then I'll buy another truck when I get back on my feet.
Well, Not sure what to make of it.....put in new IAC ran a bottle of Seafoam through intake via vacuum line off brake booster - drove truck 37 miles at 50mph plus most of the time. runs like a raped ape, idles a bit rough with needle hovering around 900 rpm but no CEL coming on. gonna pull o2 sensor tomorrow or tuesday and run it again and see if there is any change. Won't sell truck (wife won't part with it, she's REALLY attached to it) plus we've already got $1600 in trans rebuild, $1,000 in tires and $2300 in paint. At this point I'll save up for engine rebuild if that's what it comes down to. Plus I'm already selling my 99 if I have money left over I can use some of that to fix hers if need be.
