1999 Dodge Ram Fuel Delivery Problem
Old Aug 11, 2013 | 11:53 AM
gordyblackcat's Avatar
gordyblackcat
Default 1999 Dodge Ram Fuel Delivery Problem
1999 Dodge Ram 2500 v10 won't start, it was running fine, shut the motor off, and now it won't start...tried starting fluid and it will fire on the starting fluid but that's it...?
Old Aug 12, 2013 | 12:56 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome back to DF. I will move your post to the correct section.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Aug 12, 2013 | 08:43 AM
Does the fuel pump run when you first turn on the key? Can you test fuel pressure?
Old Aug 12, 2013 | 12:06 PM
Matt Nickerson's Avatar
Matt Nickerson
Is there gas in the tank? Fuel gauges aren't always correct.. I learned that yesterday after dropping the tank because I figured my fuel pump was toast, fuel gauge just decided it would be an 1/8 tank off.
Old Aug 12, 2013 | 06:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A fuel pressure tester is needed to verify pressure.
