Transfer case front output shaft
Old Aug 16, 2013 | 10:16 PM
Bobby9498's Avatar
Bobby9498
Hmmmmmmmm so many options. Might just do a whole 3/4 ton swap, everything bolts right up to the front axle right?i don't have a welder nor am I very good with one so.
Old Aug 16, 2013 | 10:42 PM
The only real issue is the rear springs. 3/4 tons are 3 inches wide, half tons are 2.5. So, either need to change the spring hangars on the frame, or, the spring perches on the axle.
Don't forget to grab the controls arms for the front axle as well.
Old Aug 19, 2013 | 09:00 AM
Sheriff420's Avatar
Sheriff420
Call these guys to see if they have what you want.
http://mintonmotorsinc.com/index.html
Old Aug 20, 2013 | 05:59 PM
Bobby9498's Avatar
Bobby9498
Ok sorry to be an idiot, I figure I'm not goin to waste my time rebuilding the thing I'm just gonna buy a new one, but I keep getting asked for the assembly number, does it
Really matter? I found one but it doesn't have a tag that I can match assembly numbers up with.
Old Aug 20, 2013 | 09:30 PM
Should be a round tag on the back side of the t-case. You want an NV231D?? (HD, or LD. HD preferrably, if you can find one. LD are pretty common.) Year makes a difference as well, shift pattern changed in 98 or 99.... What year is your truck?
Old Aug 21, 2013 | 12:33 PM
Bobby9498's Avatar
Bobby9498
Ya it's a 96, nv231D, will The hd or ld bolt right up cause the transfercase I found does not have the tag on it but it came out of a 96. I can't see dodge changing it but every scrap yard i call seems to make a big deal out of it
Old Aug 21, 2013 | 01:00 PM
HD is a about an inch or so longer, I think, but, should bolt right up. If the t-case is out of the same year/weight rating truck, its a direct swap.
Old Aug 23, 2013 | 05:34 AM
Bobby9498's Avatar
Bobby9498
Ok, does auto vs 5 speed make a difference? Like if I take one out of an auto And bolt it up to 5 speed?
Old Aug 23, 2013 | 09:33 AM
I seem to remember something about the manual trans having a somewhat longer input hub. (probably not the correct term.... but, the part that the output shaft from the tranny pokes into.) Not 100% on that though.
Old Aug 25, 2013 | 09:33 PM
Bobby9498's Avatar
Bobby9498
Well I just picked one up today so I will let you know how I make out
