Driveline Clunk
Old Aug 15, 2013 | 11:00 PM
bjpomeroy's Avatar
bjpomeroy
Default Driveline Clunk
I'm going to attach myself to this thread because I really don't know what you guys are talking about. But I've been having what I think(hope) is a trans issue. Had my trans rebuilt about 12k miles ago, and have had it in the shop repeatedly afterwards. Thought it was fixed but now when it shifts into second, if I don't have my foot in it, it makes a clunking sound as it shifts. My trans is still under warranty, which is why I hope it's the trans and not the rear end. Any ideas?
Old Aug 15, 2013 | 11:04 PM
Breaking this out into it's own thread for you, as your problem is quite different. (and thread jacking is frowned on. )
Check for driveline slop. Especially U-joints. Put the trans in neutral, (block front wheels) and see how much you can turn it. Shouldn't go far.
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I'd be looking at the u-joints and the trans. mount.
Mine does something similar, and I think my trans. mount is suspect.
Old Aug 15, 2013 | 11:37 PM
bjpomeroy's Avatar
bjpomeroy
I work this weekend, so I will have to do it next weekend. Being that I'm mechanically inclined but not that knowledgeable about how this stuff works. If I put the truck in nuetral, how do I check for slop, since I will be able to turn everything freely. Also, I don't know if this matters or not, ( don't know the technical name) but I have the rear end that when you spin one wheel forward the other turns in reverse.
Old Aug 15, 2013 | 11:40 PM
dodge dude94
You try turning the driveshaft back and forth by hand and observe what it does.
And you have an open rear end, basically under a limited traction situation, you're going to spin one tire more than the other.
Old Aug 15, 2013 | 11:57 PM
bjpomeroy's Avatar
bjpomeroy
Ok. I can probably do that before work on Saturday. I'll post my results. Thanks guys.
