Another plenum question, need opinions
Old Aug 16, 2013 | 09:56 PM
rtaylor's Avatar
rtaylor
Default Another plenum question, need opinions
Hey, need opinions my 99 2500 has 159k on it and I was wondering if its possible for one to run without the plenum being bad?? I do not have any codes and the truck runs great and no plug fouling so could it be possible that its still ok?? It uses oil, more when I am towing a load so this is what has made me think it could be bad and this is why its using oil??? Its funny that everything I have read says that usually they ping and foul the number 8 plug etc but mine runs great, I know that I need to look inside down the throttle body to see which I have not but was wondering if anyone else has had this happen, thanks in advance.
Old Aug 16, 2013 | 10:04 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Of the zillions of Plenum related threads, why must there be "Another plenum question"?
Old Aug 16, 2013 | 10:06 PM
Oil consumption is one symptom, but, it could have other causes as well. Only way to know for sure is to remove the throttle body, and take a look around. Mine was so bad, all I had to do was crack open the throttle blades, and I could see pooling oil on the bottom of the manifold.....
Old Aug 17, 2013 | 12:14 AM
rtaylor's Avatar
rtaylor
Thanks for the reply, I asked due to the fact that I am in the process of moving and using my rig to pull a trailer loaded and since there was no info in the current plenum threads related to my issue/question that is why I asked for opinions from other Dodge owners and as usual there is always a smart *** with some stupid comment, but Hey you thanks for your thoughtful response.........
Old Aug 17, 2013 | 01:56 PM
Spillage's Avatar
Spillage
Increased oil consumption when loaded could just a bad PCV valve.
Old Aug 17, 2013 | 02:23 PM
Gaius's Avatar
Gaius
At that mileage, I would pull it and replace anyway if you're planning on keeping it. It's not a very hard repair. Also a good time for the coolant bypass hose and thermostat anyway.
