1996 dodge truck
Old Aug 17, 2013 | 10:18 PM
stalvey49's Avatar
stalvey49
Default 1996 dodge truck
I have a 1996 dodge truck frame with a 360 auto 4x4 I was told it was a 360 how can I tell a 318from a 360 with out tearing down the engine the truck has no title or vin it has a 1941 body on ti
Old Aug 17, 2013 | 10:40 PM
AtomicDog's Avatar
AtomicDog
The block is stamped on its side with either 360 or 318.
Old Aug 18, 2013 | 12:08 AM
stalvey49's Avatar
stalvey49
Default 360 or 318
It has this number cast into the block 53006774 318 28 does this mean its a 318
Old Aug 18, 2013 | 12:43 AM
AtomicDog's Avatar
AtomicDog
Sounds like its a 318 - are you seeing these numbers around the starter side of the block?
Old Aug 18, 2013 | 08:43 AM
That is a 318.
Old Aug 18, 2013 | 06:57 PM
stalvey49's Avatar
stalvey49
just in front of the starter if it is a 318 then I am going to buy a 2500 with a 360 auto 4x4 for this build and put the body on the frame because I don't have the 41 frame so ill have a 2500 4x4 41 dodge
Old Aug 18, 2013 | 07:06 PM
AtomicDog's Avatar
AtomicDog
If the transmission is bolted to the motor OK, you should only need to find a 360 engine, as the transmission will fit either a 318, 340 or 360 motor. Can you possibly open the hood and share a picture or two of the existing motor/transmission?
