AC cold, then not so much
Old Aug 19, 2013 | 11:51 PM
jamesnb's Avatar
jamesnb
Default AC cold, then not so much
The AC starts out nice and cold then after about 20 min it's just cool and humid and finally turn hot. If I turn it off for a while or turn off the engine, it's cold again when I start it up.
I added one can of freon (bringing the low pressure side to about 35 psi not correcting for ambient temperature) and it's better but not constantly cold.
I can hear the compressor come on when it's parked.
It's an '01 with a little over 200K miles, no A/C work ever performed on it.
Any ideas?
Old Aug 20, 2013 | 12:36 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Does your blend door work?
Old Aug 20, 2013 | 12:43 AM
jamesnb's Avatar
jamesnb
Meaning I can adjust the thermostat? I can try it tomorrow. I usually keep it set a max cold because the heater core is leaking.
Old Aug 20, 2013 | 12:47 AM
dodge dude94
Eh, something like that.
The blend door changes the amount of heat and cold you're getting through the vents.
Old Aug 20, 2013 | 12:52 AM
jamesnb's Avatar
jamesnb
Does it work off vacuum? If so, that would fit what I'm seeing. If it does work off vacuum, is the hose easy to get to? I have a vacuum gauge.
Old Aug 20, 2013 | 12:53 AM
dodge dude94
It's an electric motor.
You might have wild vents, do a search here on DF for more information.
Old Aug 20, 2013 | 01:24 AM
Gaius's Avatar
Gaius
Try measuring and adjusting the air gap on the compressor. SHould be less than .55 if I remember right.
Old Aug 20, 2013 | 09:22 AM
SilverSS's Avatar
SilverSS
^^^that. Also make sure it's draining properly and not backing up. Does it happen when you go down the road at a constant speed for a while without stopping? Make sure it's not freezing up also.
Old Aug 20, 2013 | 11:45 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Fixed the same issue on a friends truck, he installed 2 new check valves from the dealer.
Old Aug 20, 2013 | 06:43 PM
jamesnb's Avatar
jamesnb
I did a little more troubleshooting...
*The air blows out the right vents when I change the selector, even after it stops cooling.
*It stayed cool almost all the way home today (25 min). The last 5 minutes it stopped cooling. I left the engine and the A/C on when I parked in the driveway. The compressor was NOT engaged.
*I turned off the A/C and the engine. About 30 minutes later I started the engine and turned on the A/C and the compressor engaged right away.
*My commute is mainly highway/constant speed. Once it stops cooling, it doesn't start cooling again until I turn off the A/C or the engine for a while.
*I don't believe it's clogged or freezing up.
*Can you elaborate on the air gap? Is it the space between the pulley and the compressor housing?
*I'm thinking it's a bad compressor switch or a short in the wiring to the switch.
What do you think?
Thanks
