stalled while driving
Old Aug 22, 2013 | 01:50 PM
DavidHendrick's Avatar
DavidHendrick
Default stalled while driving
I have a 1999 ram sport today when I slowed down to take a curve she stalled out and won't restart. There is a strong gas smell, but there is spark. The motor turns over but not fire up, any thoughts
Old Aug 22, 2013 | 04:58 PM
Matt Nickerson's Avatar
Matt Nickerson
Well if you're getting adequate spark (nice blue arc from the plug), then I would be looking for a fuel delivery issue.. Does the pump prime with the key turned on? Will the truck start with starting fluid?
Any check engine codes?
Old Aug 23, 2013 | 10:24 AM
DavidHendrick
Plenty of fuel to the top of the system carb smells flooded
Old Aug 23, 2013 | 10:39 AM
Pull a plug or two, see if they are fuel soaked. If so, could be bad coolant temp sensor. (or, it may have just come unplugged.) Such a failure makes the PCM think it is -40 degrees outside, and it positively DUMPS fuel.... If you put the pedal to the floor, and hold it there, will it fire up?
Old Aug 23, 2013 | 12:54 PM
af78954's Avatar
af78954
I'm having a similar problem with my 98 5.2l today. Driving & all of a sudden it stalled out. My truck seems to have spark because it cranks over but does not stay on. It kinda sounds like there no fuel going in. Any other ideas?
Old Aug 23, 2013 | 10:11 PM
Paul DeHayes's Avatar
Paul DeHayes
As mentioned above, check to make sure your fuel pump is priming at start-up. If it isn't, could be the pump or the pump relay....
Old Aug 23, 2013 | 11:26 PM
DavidHendrick
It is the temp sensor according to diagnostics thank you all for the help
