engine swap
Old Aug 27, 2013 | 02:48 PM
heminutt's Avatar
heminutt
Default engine swap
I have a 99 1500 2wd with a 5.2 46re trans. I am looking at putting a 360 in it what will I all need and what would be the best year to swap with. I fond a 94 360 but can look for a better year
Old Aug 27, 2013 | 03:02 PM
Use the search function. Tons of engine swap threads.
Old Aug 27, 2013 | 03:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Please read: Thanks, and Welcome to DF
https://dodgeforum.com/forum/2nd-gen...new-topic.html
Old Aug 27, 2013 | 04:57 PM
aofarrell2's Avatar
aofarrell2
It really doesn't matter what year, but to make it easy, find a 99, and grab the PCM and engine wiring harness. Your 5.2 PCM won't control a 5.9 without special tuning, such as Hemifever SCT.
If you got the 1994 engine, you will need to swap your injectors, and all sensors over from your 99 and get the PCM tuned.
Old Aug 27, 2013 | 06:13 PM
heminutt's Avatar
heminutt
if I got the pcm out of the 94 also would it work ok.
Old Aug 27, 2013 | 06:19 PM
aofarrell2's Avatar
aofarrell2
The engine would run, but your instrument cluster, and possibly transmission, would not.
Old Aug 27, 2013 | 06:20 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^Yeah. +1
You need a 99+ PCM IIRC, for everything to work properly.
Old Aug 27, 2013 | 06:22 PM
aofarrell2's Avatar
aofarrell2
A 99 or 00 PCM, in 01 they changed PCMs, a 98.5 should work as well.
Old Aug 27, 2013 | 06:28 PM
heminutt's Avatar
heminutt
ok so all I will need is a 99/00 pcm any year 360 as long as I put my sensors on it and the 360 flex plat or is there more
Old Aug 27, 2013 | 06:29 PM
dodge dude94
Should work. If you have the time, you will want to put your intake manifold off your current engine onto the new engine though, it will have the correct temp sensor locations and won't have EGR or the center divider.
