Oil Pressure problems
Old Sep 3, 2013 | 12:59 AM
Weld_It33's Avatar
Weld_It33
Default Oil Pressure problems
I have been searching the forum for a diagnosis, and can not seem to find the same issue. My oil pressure is good at idle right around 40 psi. once i accelerate it rises to 60 -80 I would say. oil level is good, wondering if it is the sending unit?
Old Sep 3, 2013 | 01:00 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Well, without confirming with a good known mechanical gauge, I'd say that's pretty normal and pretty damn good at that.
Old Sep 3, 2013 | 10:04 AM
I agree with him. ^^
Old Sep 3, 2013 | 10:07 AM
kejobe's Avatar
kejobe
Normal.
Old Sep 3, 2013 | 10:39 AM
Sounds perfectly normal to me.
Old Sep 3, 2013 | 12:24 PM
Ramman18's Avatar
Ramman18
That's what it should do! Mine is the same way and has been since new. Only once did it run low when I ran some 10w30 in summer heat. With over 100k miles, use thicker oil.
Old Sep 3, 2013 | 08:04 PM
Weld_It33's Avatar
Weld_It33
Talking
Thank you all very much. I just put the Hughes plate on this weekend... my gauge never did that before haha. must mean its fixed!
Old Sep 3, 2013 | 11:13 PM
kejobe's Avatar
kejobe
It probably did it before, you just didn't notice.
What happens is when the rpm's go up the oil pump spins faster, that increases the flow (volume). Since there is more volume, the pressure increases.
This will explain:
