Whoops, my bad.
Old Sep 3, 2013 | 10:39 PM
keepitrunning's Avatar
keepitrunning
Default Whoops, my bad.
Hello, I changed out my cap and leads tonight and inadvertently crossed #5 and #7, ( aft R/H corner). Noticed the miss and found the mistake. I now have a check engine light on my cluster.
Does anyone know how to clear that light on a 98 1500 SLT, 5.2 litre? Any help is appreciated.
Old Sep 3, 2013 | 10:42 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I don't know if it will work on the 98, but there are two procedures for the newer trucks: the key dance trick and just disconnecting the battery for five minutes.
The key-dance trick involves turning the key on (no engine start) and off 3 times, leaving the key on for the 3rd time. Dunno if it will work or not, 98 was a weird year.
The other is to just disconnect the negative battery cable, turn the headlights on, wait 5-10 minutes, turn the headlights off, and re-connect the cable.
Old Sep 3, 2013 | 11:25 PM
keepitrunning
Thank you Mr. Dodgedude. Disconnected battery, tidied shop, reconnected and no check engine light! If only everything mechanical was that simple.
Old Sep 3, 2013 | 11:37 PM
dodge dude94
Bingo, there you go.
Old Sep 4, 2013 | 01:54 AM
Gaius's Avatar
Gaius
Pulling the PCM plugs work well for me, quicker than resetting the damn radio settings.
Old Sep 4, 2013 | 02:09 AM
dodge dude94
^My Infinity headunit doesn't reset anything but the time.
Old Sep 4, 2013 | 04:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The key trick will not work on a 98. Besides, even if it did, you can't reset the pcm that way , the key trick is only for reading any codes that might be stored. Disconnecting the battery as stated or a scanner is the only way to reset the pcm.
Old Sep 4, 2013 | 08:49 PM
h3lzsn1p3r's Avatar
h3lzsn1p3r
you could have left it the light goes off after a few starts once the issue is fixed
Old Sep 5, 2013 | 06:12 PM
zman17's Avatar
zman17
This is a very bad procedure, one small short or spike will destroy the PCM. Please do not suggest this to people.
Disconnecting the negative battery cable (before) replacing or fixing anything electrical, is the best way for the pcm to reset and learn the new settings of said fix or replacement.
Old Sep 5, 2013 | 06:22 PM
moe7404's Avatar
moe7404
on small block and big block, my dad made up this saying. #5 is allways before #7, in cap and left bank. its easy to remember.
