stalling problem
Old Oct 1, 2005 | 05:20 PM
01sport's Avatar
01sport
Default stalling problem
I have a 2001 dodge ram sport 1500 that I bought almost a year ago, it has 72,000 miles on it.
yesterday it started stalling on me whenever I would slow down or stop the rpm's would flutter then drop and stall, it only did this after the engine warmed up.
now this morning I changed the air filter and replaced the pcv valve and it didnt help any.
i'm leaning towards it being the o2 sensor but i'm really not sure.
any suggestions on what it could be?
thank you
Brian
Old Oct 2, 2005 | 11:09 PM
dodgebeater38's Avatar
dodgebeater38
Default RE: stalling problem
mine did sumthin like that and it was a week battery and altinator problem
Old Oct 16, 2005 | 12:04 AM
rebelgtp's Avatar
rebelgtp
i'm having a similar issue with my 95. do you have any problems starting your truck back up if you let it sit for a few minutes after you had it running and warmed up?
Old Oct 16, 2005 | 02:52 AM
QuadCab318's Avatar
QuadCab318
go read rebelgtp's problem https://dodgeforum.com/m_287321/tm.htm
Old Oct 17, 2005 | 12:25 AM
steve05ram360's Avatar
steve05ram360
sounds like a dirty throttle body and IAC valve. pull the TB and give it a good cleaning and make sure the small air passage ways are free of dirt and are clean. then clean the IAC valve and make sure it's in good opperating condition. you might want to spray a dab of oil on the shaft to make sure it can adjust easily and not stick.
Old Oct 17, 2005 | 06:34 PM
01sport's Avatar
01sport
it was the crankshaft positioning sensor, it was a 95 dollar part.
