1995 1500 5.2 gas getting in the engine oil!
Get a fuel pressure tester. Start motor with the gauge hooked up, see what the pressure is. Turn motor off and see if the pressure holds. If it doesn't, the regulator on the fuel pump might be bad or you have a leaking injector. To isolate the two, start motor again w/gauge hooked up. Get another person to sit in truck and get a c clamp or something to pinch off the rubber fuel supply line near where it connects to fuel rail. Have the person in the truck shut it off while you quickly pinch off that line, that will eliminate the regulator on the pump from the equation. If the pressure does not hold, you have a leaking injector or more.
