Timing Chain
Old Sep 21, 2013 | 04:53 PM
  #31
TheBigRedTruck's Avatar
TheBigRedTruck
i got the bolt on but im unable to tighten the bolt to spec (135 lbs. ft) because the crank turns. How can i make it stop
Old Sep 22, 2013 | 08:55 AM
  #32
Snowfan's Avatar
Snowfan
On mine I used some baling wire, several loops, and wired the pulley to the frame/pit arm-whatever was solid and handy. Totally hillbilly but it worked well.
Old Sep 23, 2013 | 04:02 PM
  #33
TheBigRedTruck
I tried it and it worked, only problem was the adapter I had on my torque wrench snapped off before I could get to 135ftlbs. Man that bolt goes on tight!
Old Sep 24, 2013 | 07:14 AM
  #34
Snowfan's Avatar
Snowfan
I know what you mean. I have an old Mercedes that I am finishing up a chain on. The crank bolt torques to 300. It was suggested to me to get a 6ft cheater bar and when the socket explodes it should be close enough.
Old Sep 24, 2013 | 08:42 AM
  #35
Holy smokes....... Careful where you position yourself when you do that. I knocked myself out when a socket exploded when I was trying to break loose lug nuts. Smacked my head on the fender..... next thing I knew, I was on my back, with people standing around looking down at me..... had a serious headache too......
Old Sep 24, 2013 | 06:47 PM
  #36
lwiuff's Avatar
lwiuff
Man, you guys are funny! Now I know what NOT to do when I do my chain & gears next month or so... Seriously, I appreciate the posts on this forum - they have made my life easier and saved me a buttload of cash.
Old Sep 24, 2013 | 07:07 PM
  #37
TheBigRedTruck
be careful when putting the water pump and timing chain cover back on, they share some bolts so you will have to out them on at the same time to tighten them correctly.
Old Sep 24, 2013 | 07:29 PM
  #38
Not to mention the two bolts that come up thru the oil pan... so, you are trying to tighten things in two directions. (I didn't oil pan fairly snug first, tightened everything else, then torqued them to spec.) Careful when you take it apart not to tear that gasket.
