1996 ram 2500 trany shift
Old Sep 18, 2013 | 07:16 AM
allvetts's Avatar
allvetts
Default 1996 ram 2500 trany shift
i HAVE 1996 RAM 2500,
The trans, (automatic ) shifts regular, until I am at a light, and I give it a lot of gas, then it shifts fine through 2nd gear, then takes alot to get to 3rd and forth. Down shifts irregular too, when going up a hill. But! if I shut it off, and start again, it's
fine. only when I drive aggresivly it takes a high RPM to get it to 3rd gear.
had the fluid changed, but still the same.
Old Sep 18, 2013 | 08:15 AM
Welcome to DF! Moving this to the 2nd gen Ram section.
Old Sep 18, 2013 | 11:21 AM
Standard problem. At large throttle openings, the governor pressure sensor sorta 'fails'... so the PCM doesn't know what to do with pressure. Replacing it might help.... or not.
