97 Ram 1500 oil problem
Old Sep 25, 2013 | 05:26 PM
AlanDeplae's Avatar
AlanDeplae
Default 97 Ram 1500 oil problem
hey all im new to the dodge forum. I got a issue i was wondering if anyone else has had. So ive had my truck for a little while its a 97 ext cab ram 1500 with a 5.9 in it. I changed the oil when i first got it about 6 months ago. I checked the oil in it the other night and it was bone dry. I put 3 quarts of oil in it that night. Was planning on a oil change for the weekend. The 3 quarts put me on the safer side rather running no oil. Was on the express way and my oil pressure gage went from 40 were it normally is, to 0 and back to 40. It did this a few times. Then after about 3 times of doing this it went to 0 and stayed there. I was driving on the expressway at the time and was 3 miles from the next exit. The truck started ticking. So i figured i had a oil leak got off at the exit to gas station ran in and got some oil for it. When i pulled the dipstick to check it my oil was over filled. way over filled. Like almost 2x what it should have been!!! How if i only put 3 quarts in? So after the truck sat for a few mins i started it back up and drove it the 2 blocks back to my house. About 3 mins after i started it the oil press drop back to 0 and oil light stayed on.... anyone had this happen? Is it my oil pump? or my pressure unit? Clogged filter? anyone help with ideas before i tear it down and buy un needed crap would be helpful.
Old Sep 25, 2013 | 05:37 PM
Matt Nickerson's Avatar
Matt Nickerson
So... how many quarts of oil did you put in your truck? 3?! Truck should hold close to 5-5.5qts on avg. Not sure what your doing with adding three quarts. And the way you check oil is on a cold engine, like let-sit-overnight-cold engine. You pull the dipstick out, wipe it off, stick it back in, pull it out and the oil level should be at the top line.. 1/8" over is acceptable.
If you too much oil in, it will foam up and ruin your engine. If you put too little (ie 3 quarts) its gonna ruin your engine. Put 5+ qts in and see how oil pressure does. You should also be using a mechanical gauge, as dash gauges are not an accurate way to measure your psi.
Old Sep 25, 2013 | 09:13 PM
AlanDeplae's Avatar
AlanDeplae
Default Thanks
Thanks matt. Will do. If oil pressure does not come back after putting right amount of oil in, should i change oil pump and the pressure unit? Seen how there not expensive figure it would make a good project maybe?
Old Sep 26, 2013 | 11:20 AM
What did your oil look like? Wasn't chocolate milkshake was it?
