Fuel sync ?
Old Sep 26, 2013 | 11:47 PM
getdown78's Avatar
getdown78
Default Fuel sync ?
I just swapped a 5.2 (truck had a 5.9) in my 96 ram 1500 and it seems to idle low and if you give it some gas and when it idles its self down it sometimes will die out ? Is this a fuel sync problem or pcm flash ?
Old Sep 27, 2013 | 12:04 AM
Ham Bone's Avatar
Ham Bone
Sounds like a IAC or TPS problem tbh
Did you use the 5.9 PCM?
Old Sep 27, 2013 | 12:20 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
The 5.9 PCM is gonna be tuned rich for the 5.2
Old Sep 27, 2013 | 10:10 AM
getdown78's Avatar
getdown78
Can i possibly use a scanner and retune it or have to use a tuner ?
Old Sep 27, 2013 | 10:12 AM
Need a tuner. Scanner won't do that particular trick.
Clean Throttle body, test TPS. See if that doesn't help.
Old Sep 27, 2013 | 10:33 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
As said, it's a PCM issue. Go find a 5.2 PCM or go the dealer reflash route. Unless you know someone that has access to the Chrysler tool AND knows how to do it.
