axle seal
Old Oct 2, 2005 | 09:52 PM
dodgebeater38's Avatar
dodgebeater38
Default axle seal
cant get pasanger side axle seal in need some tips please
Old Oct 3, 2005 | 02:39 AM
richardmoore's Avatar
richardmoore
Default RE: axle seal
I took mine to a shop, didn't want to mess with it myself. Thats the only advice I have to offer sorry. My mechanic rigged up some device with a threaded rod to slowly pull the seal into place without beating it in an risking damaging it.
Old Oct 3, 2005 | 03:32 PM
2001ramsport's Avatar
2001ramsport
It's really not that hard to change,I changed mine about a month ago.I made a tool to install it .
Old Oct 4, 2005 | 12:57 AM
The Burning Rom's Avatar
The Burning Rom
http://dieselpowerman.tripod.com/Fro...xle%20Tech.htm
This is for a DANA 60, but the idea is the same.
Old Oct 4, 2005 | 01:05 AM
dodgebeater38
thanx for the input i found a peice of exaust pipe the same size as the seal welded it to a 3/8 fender washer and used threaded rod it took 5 minutes to instal after that
Old Oct 4, 2005 | 11:05 AM
2001ramsport
Now thats what I like to hear
Old Oct 4, 2005 | 11:21 AM
Blackimpala's Avatar
Blackimpala
When you used the exaust pipe did you have to remove the ring and pinnion?
Old Oct 4, 2005 | 07:20 PM
dodgebeater38
no the pasenger side it located on the outside of th cad cover so i did not have to remove anythig other then that
