2000 ram 5.9cummins cutting out and dieing
Old Sep 30, 2013 | 07:51 AM
hadhwy138's Avatar
hadhwy138
Default 2000 ram 5.9cummins cutting out and dieing
Hi all haveing issues with motor cutting out and ultimately dieing acts like its grounding out soome were first time it did it I was idleing through a parking lot it started cutting out I thought ignition switch was sticking or not making good connection so I messed with it a little and it seemed to go away that was a month ago now its starting again and now its not only cutting out its dieing also ive check for bad connections and or shorts would really like to know what you guys might think
Old Sep 30, 2013 | 11:32 AM
Welcome to DF! Post your question in the 2nd gen Ram technical section. This section is for issues with the Dodge Forum internet site.
Old Sep 30, 2013 | 12:53 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Moved to th proper section. Good luck. THe members should be able to help you out better in this sections
Old Sep 30, 2013 | 02:16 PM
Cam or crank sensor would be my first guess.
Old Sep 30, 2013 | 11:21 PM
master tech's Avatar
master tech
Site Moderator & Tech
Also check the wire harness near the shock tower. On the encore motors, there was a problem with harness rubbing on the shock tower. Next would be the crankshaft sensor.
