46rh replace 46re
Think I may have found the problem. It appears I put the wrong 02 Sensor in. The one I bought a few days ago was for the front of Cat. I put it in the back of Cat. Just sent the wife for a new rear of Cat Sensor. I hope this corrects the problem. I will also check the Crank position Sensor.
Thanks-
Thanks-
The sensor itself is the same, if it plugged into the harness (the correct one, as in if you installed it to the rear, "post cat" and plugged it into the rear harness) all is good. The only difference is wire length and plug styles.
Yes. I see what you are saying. The connectors look similar, but they are slightly different in that you can't plug in to the wrong one. I bought a Bosch #15730 02 Sensor for the Post Cat., and a Bosch #13280 for the Pre Cat. The problem is that they both will plug in to the Post Cat connector.
In my previous posts I mentioned that I would get an occasional ( once a month) PO138 Code so I replaced the rear sensor with the Bosch 15730. The vehicle ran but started to studder, pop, backfire, etc., only under a load. If I shut the engine off and then restarted it, it would run great. Now the vehicle seems to run well. but throws a PO132 code. I'm still trying to figure out how to remove that front sensor. They are a real Bugger!
I will be replacing the 46RE on my 2000 Ram 1500 5.2 4x4 this week. I plan on doing this with help from a friend. Are there any tricks or tips anyone can offer? I have the complete service manual. It looks to me that the most unpleasant task will be removing the exhaust as the driver side pipe loops right under the tranny.
I have done some auto. tranny's in the past and I have all the necessary tools as well as an ample supply of cold Budweiser.
Thanks-
Thanks-
Firmly push torque converter straight in and turn clockwise .
You're looking for 3 distinctive clunks as it goes in
Very important
hdy i have a question if thats ok not sure wer im Supose to be doing tjis but i cant find anywere that says make new post or whateveer anyine no what other trannys swap out with my 46re? Incase i see a deal i might get thnx and sry for butting in
The RE trans showed up in 96, and was used until around 2002 or 3 or so in trucks. Things changed in 2000 with the internal electronics, and at some point, it went from a 3 wire neutral safety switch, to a five wire 'range sensor'.... Don't recall when that latter one happened.
