Where is the Fuel Injector replacement thread??
Old Oct 8, 2013 | 06:44 PM
Big Jeff's Avatar
Big Jeff
Default Where is the Fuel Injector replacement thread??
Did several searches and did not find a DIY to changing a fuel injector.
Got a P0207 code "Faulty #7 fuel injector"
Thanks
Old Oct 8, 2013 | 07:22 PM
Matt Nickerson's Avatar
Matt Nickerson
Is the truck misfiring? If not just erase the code and see if it comes back.
If the truck runs rough, check the wiring and harness/connector for the injector. If that's allset, then replace the injector. Get a Haynes manual if you don't know how to replace it. You basically just disable the fuel, pull off the injector connector, and pull the injectors off. Replace the orings a well or you'll risk leaking injectors.
Old Oct 8, 2013 | 09:53 PM
ryan0714's Avatar
ryan0714
yea pull the fuse for the fuel pump, pull all the connectors for the injectors on that side, and pull the fuel rail up and take all the injectors out of their hole on that side, then just take off number 7, replace, and put it all back, change the rings, and use a little vasoline on them when puttin the injectors back into the manifold, or else u run the risk of ripping one...
Old Oct 10, 2013 | 09:01 PM
Big Jeff's Avatar
Big Jeff
Can't believe no one in town had an ejector, have to wait til tomorrow. I did get the old one out.
Old Oct 11, 2013 | 08:50 AM
ryan0714's Avatar
ryan0714
cool deal just remember to lube the new o rings or else they may rip when you push them down into the seat.
Old Oct 11, 2013 | 09:06 AM
gertie240's Avatar
gertie240
my grandfather had to tell a newby tech at the dealership about Vaseline and o rings. But then again he was an AP mech during the Big one.
Old Oct 11, 2013 | 04:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks
Go the FAQ/DIY section and download the free 01 service manual.
Old Oct 11, 2013 | 08:31 PM
Big Jeff's Avatar
Big Jeff
***Update***
Installed new injector($70.00) no problems with install. Reset computer ran fine for 5 min. started running ruff, code came back. The wire harness feel fine, check connections, felt along wires.
I'm wondering if my replacement PCM is bad again? The first replacement was crap and now it's been 2 1/2 months since the second one. I guess I could get one from junk yard and see if it eliminates problem then I would know that it is a PCM malfunction.
Old Oct 11, 2013 | 11:37 PM
ryan0714's Avatar
ryan0714
you could, but make sure its same year and model as far as 2wd or 4wd.
Old Oct 15, 2013 | 08:25 PM
Big Jeff's Avatar
Big Jeff
Problem Fixed. Wire above air intake was chaffed through! Yeah.
Thanks
