PO351, Cuts out,Stalls,Backfires...
Old Oct 9, 2013 | 03:27 PM
DodgeRam10's Avatar
DodgeRam10
Default PO351, Cuts out,Stalls,Backfires...
Few months ago my truck cut out driving down the road, found out it was my fuel pump. Ordered a new pump and installed and everything was good. About 3k miles later, my truck would not start periodically and then wouldnt start at all. I assumed it was the pump but foud it to be a weak/bad coil. Replaced coil and solved the problem. Now about 3 months later, my truck cut out and start slowing down,backfired once and went away. Then today, cut out and died. Pulled over and it started right away. Threw code po351 which is coil circuit code. So is my coil defective already? Msybe pcm? Any other thoughts? Would the coil cause the backfire, maybe by gas building up with no spark for a second and igniting at once? Thanks
Old Oct 9, 2013 | 05:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the coil wire.
Old Oct 9, 2013 | 09:56 PM
DodgeRam10's Avatar
DodgeRam10
Ok I will make sure its on tight. As far as replacing goes, I put taylor thundervolt wires on last year when I did my plenum so it shouldnt be bad.
Old Oct 10, 2013 | 06:07 PM
zman17's Avatar
zman17
I dont mean check for tightness, I mean check that it is not rubbing on something and has gone through the casing.
Old Oct 11, 2013 | 08:52 PM
DodgeRam10's Avatar
DodgeRam10
Wires look good, no worn spots. Truck did it again today. Driving 55 and truck starts cutting out, then truck backfired and cleared up. No code this time. I replaced the coil under warranty for the heck of it to eliminate the coil. Any other ideas if it does it again?
Old Oct 12, 2013 | 12:40 PM
Cam or crank sensor.
