new transmission question
Old Oct 9, 2013 | 06:57 PM
ScreamingNeedle's Avatar
ScreamingNeedle
Default new transmission question
OK so i have a 1997 DODGE RAM 1500 4X4 with 5.9 gas, Already figured out it is a 46re transmission (automatic). Can I swap it out with a 46re tranny from a 2001 1500 4x4 with 5.9? Read somewhere that the electronics were switched up in these transmissions somewhere around 99-2000. If it is possible are there certain items that need switched? Or anything that needs done with computer. Any help would be greatly appreciated.
Old Oct 9, 2013 | 07:36 PM
dhvaughan's Avatar
dhvaughan
i think you'll have to swap some electrical connectors from your 97. zman will know.
Old Oct 10, 2013 | 10:30 AM
Governor pressure sensor and solenoid are different, need to swap those, and the plate they mount to. I think the pinout for the TCC and O/D solenoids are different as well, so, need to replace those as well. All in all, couple hundred bucks in sensors and such.
Old Oct 10, 2013 | 06:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1 on all counts. And you can change the TCC/OD solenoid assembly without removing the valve body.
Old Oct 10, 2013 | 08:15 PM
dhvaughan's Avatar
dhvaughan
his truck is a 97 with a 5.9
the new trans is an 01 from a 5.9
what should he buy new? and what should/could he move from his 97.
if he buys a new 97 Borg Warner sensor and solenoid for the $50 or so - can he move the mounting plate from his 97 to the 01.
and move the 97 TCC and O/D solenoids from the 97 to the 01.
...and when he's done, has he turned the 01 into a 97.
get a new 5.9 torque converter from Precision or other. the stock ones are crappy.
Old Oct 10, 2013 | 08:50 PM
ScreamingNeedle
Talking
Yeah what he asked .
Old Oct 10, 2013 | 10:12 PM
moe7404's Avatar
moe7404
i found this neet EXTERNAL trans filter. goes in the fluid IN line, the line on the left at the trans rear. check it out.
man o man i about forgot yes its a cut & past sorry. __________________
after you clean the trans. add this to your*chrysler*trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose. Reff:http://www.magnafilter.com
2. for other sizes wix 58964 5/16 tube size
Old Oct 11, 2013 | 04:41 PM
zman17's Avatar
zman17
All electronics need to be swapped from the 97 into the 01, and yes, also the gov body mounting plate needs swapping. The transducer/pressure switch mounts differently between the two.The TCC/OD assembly from the 01 is the main harness and will not plug into the gov transducer of the 97. So it needs to be swapped.
