5.9 magnum build
Old Oct 16, 2013 | 11:54 AM
cootersdream96's Avatar
cootersdream96
Originally Posted by Wildman4x4nut
Cooter,
Bottom line is nothing beats cubic inches. So stroking your engine to a 408 is going to get you the most bang for your buck. Now with the 96 are you OBD1 or 2? If it is OBD1 your going to run into tuning issues. I can't answer the question of can you or can't you get it to work. But if you can't tune it with the stock PCM then your going to have to go aftermarket. Look at an item called MegaSquirt for tuning your engine.
A 408 is going to give you that low end grunt for spinning larger tires. Also remember that all the engine in the world isn't going to do much if the gearing isn't changed to match tire size. So as you increase your tire size you also want to install lower gears. And then you get into the issue of axles not being able to handle tire size. You D44 front axle is good for up to a 35" tire. If you have plans to go bigger then you are going to want D60 axles front and rear. Then you're good for up to a 40" tire. Maybe 42" if you build the axles.
I drive a Jeep with D44 front axle & D60 rear alxe. I have 5.13 gears and am running 38" tires. I have a 5.9 that I am almost done building for the Jeep. My Jeep is a little on the heavy side too and weighs in at around 5,000lbs so I am moving almost as much weight as you are. Read thru some of the build threads on here. Also do a search for 408 builds. There are also books on rebuilding your engine and building a stroker engine.
Thanks for the advice , I've been reading a lot of threads on here since I joined here and there are a lot of helpful ones out there
Old Oct 22, 2013 | 06:50 AM
corbo1962's Avatar
corbo1962
Wildman is right. I was running 35's with 4.56 gears on the D44 and Chry 9.25 and everything worked great for several years. as soon as I lifted it higher and put 37's on, I broke the fornt end within a month. Had to do an axle swap to D60 front & D80 back with 5.13 gears. I hadn't planned to do the swap but had no choice. Another thing I've researched in the stroker motor is the transmission will probably have to be beefed up.
Old Oct 22, 2013 | 11:06 AM
No 'probably' about it. The stock trans is weak, and a 408 will make VERY short work of it.
Old Oct 22, 2013 | 01:37 PM
cntry_prernnr's Avatar
cntry_prernnr
how much beefing up we talkin bout?
Old Oct 22, 2013 | 02:28 PM
I would spend the money on some flavor of PATC's Viper trans. Or at the very least, a build very similar. Mega Viper would get my vote, and would pretty much assure you wouldn't have trans problems for quite some time.
Old Oct 22, 2013 | 03:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
You're probably looking at a whole side of beef
Old Oct 23, 2013 | 10:30 AM
corbo1962's Avatar
corbo1962
I also have been looking at the PATC's Mega viper, It's rated for 700hp and you can buy it outright with no core charge. It should handle all that the new stroker motor would put out.
