4wd light on after ball joint replacement.
Old Oct 21, 2013 | 01:25 PM
Arde's Avatar
Arde
Originally Posted by 98Dodgeram360V8Mag
Now that I think of it, it may have. is that the bushing that goes behind the axle nut??
The axle has a bushing in the end of it, the intermediate axle has a nub on it that fits into the bushing keeping your axles aligned.
Old Oct 21, 2013 | 01:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The smaller on the left in this pic.
Old Oct 22, 2013 | 03:06 PM
BlindU's Avatar
BlindU
sorry to thread jack, but when i removed my axle, it came out clean, with no bushing at the end. and when i looked inside, everything looked perfectly aligned. lets hope when I have to put the axle back in, i won't have any issues.
Old Oct 22, 2013 | 06:49 PM
Arde's Avatar
Arde
Put a bushing in before you put the axle in, it doesn't take much misalignment to keep the shift collar from engaging both axles. They're too cheap to take a chance on. My truck didn't have one in it when I bought it and no telling how long it had been missing. The nub on the intermediate shaft was worn to a taper and the hole in the outer axle was also tapered inwardly. It cost me two new axles to correct.
One source, I'm sure there are others
http://quad4x4.com/qu40107.html
Check the bearing/bushing for the intermediate shaft also while you've got the axle out, they're also cheap, and while you're already there is a good time to replace it.
Old Oct 22, 2013 | 08:12 PM
dhvaughan's Avatar
dhvaughan
you should remove the CAD and inspect the collar, bushings, etc. soak the 4 little bolts with pb-blaster or other.
Old Oct 27, 2013 | 12:24 PM
98Dodgeram360V8Mag's Avatar
98Dodgeram360V8Mag
I had a mechanic look at it and it ended up being something that has to do with the front driveshaft. He took the front shaft out and messed with it and said that there were some rings or something that were rubbing so he beat those back in and for about a day it didnt make a sound but now its back again.. This truck has made me so mad that i am going to go look at a different one today.
Old Oct 27, 2013 | 12:39 PM
Find a different mechanic.
Take off the cad cover. (careful, the bolts like to break) Have a look inside, and see what is going on. the switch for the 4wd light is in there. The front driveshaft has nothing to do with it.
Old Oct 27, 2013 | 07:04 PM
98Dodgeram360V8Mag
The 4wd light went off though. I took the axle out and the seal blew apart and was wound up in the gears. I took all of the shrapnel out and it still does it.
Old Oct 27, 2013 | 07:26 PM
Is it coming from the axle, or elsewhere?
Old Oct 28, 2013 | 01:11 PM
zman17's Avatar
zman17
Was the bushing in the end of the axle? Did you open up the CAD? Did you check the vacuum ?
