Looking for max flex out of my lift kit
Old Oct 24, 2013 | 02:01 PM
  #21
CoryVolkenant's Avatar
CoryVolkenant
I get the dollar saved here is dollars spent here this is by now way my first lifted or off road rig I'm just asking as many questions as I can before I invest in incorrect or not needed items I wanna build it correct the first time that's why I'm leaning on you forum people that have been down this road. I'm also the owener of a 1987 Suzuki samurai I joined a fourm about samurai sand now 5 years later I have a samurai on Toyota axles hydraulic Chevy 4.3 vortec motor high steer setup twin stick 6.5 tcase on 37s with fox air shocks among other thousands and thousands of dollars spent on it I was much younger an new in to this and I didn't ask enough questions and spent money on many crap items an mods that were not worth it so this time around I'm really trying to ask first ask again then buy, I really do appreciate the input from everyone about this
Old Oct 24, 2013 | 02:29 PM
  #22
merc225hp's Avatar
merc225hp
Your list is looking good, as you plan to use this truck hard I would skip the adda leaf and the block and look at a new spring pack, or if you live in a city find a heavy-duty spring shop and have them add two leafs and rearc the springs. Other than that you list is spot on, as for thin brackets not on a Ram I have heard Jeeps do have this issue we do not. White Knuckle is constantly wheeling his truck in the rocks and I have not heard him say squat about the frame brackets.
Tip: 3rd Gen 2500-3500 upper and lower control arms fit our trucks, I am using them in mine keep a eye open on the web for some used ones or cheap new ones. You can also build your own for about $300 and they would be adjustable if you so desired.
If things go well this weekend I will have the upper and lower arms from my truck up for grabs cheap, maybe even the newer 7" coil springs, I also have a extra Skyjacker adjustable trackbar, but not the frame bracket (very ez to make one).
Old Oct 24, 2013 | 06:37 PM
  #23
CoryVolkenant
ok question are the 2500/3500 3rd gen arms longer than our stock ones? my brother in law just lifted his 04 2500 diesel and replaced the arms up front? interested in the track bar can you tell me a bit more about the bracket i was thinking about fabing one up
Old Oct 24, 2013 | 06:46 PM
  #24
merc225hp's Avatar
merc225hp
Here are some 3rd gen arm specs for you to look over.
3RD Gen Dodge Ram Stock Control Arms:
Upper: 16 5/8"
Lower: 18 5/8"
KORE 3" Lift Control Arms:
Upper: 17"
Lower: 18 5/8
Fabtech 4.5" Lift Kit Control Arms:
Upper: 17 1/4"
Lower: 19"
Superlift 6" Lift Kit Control Arms:
Upper: 18 5/8"
Lower: 20 3/8
Fabtech 6" Lift Kit Control Arms:
Upper: 18"
Lower: 19 11/16"
TGC 6" Fixed Arms:
Upper: 18 13/16"
Lower: 20"
If you have acess to a metel brake and a tig welder the frame bracket is very ez to copy or make better.
Some pix of it, if you need a more detailed info I can go measure it every which way for you.
This is the spare track bar I have.
