Do you know if something should be plugged in here?
Can you post a pix of said reservoir, it should be the overflow bottle for the rad. The horn is on the pass side? must be a year differance thing mine are under the bumper on the drivers side.
I tried but i got a message about my quota being met
If you are trying to use a attachment from df to post a pix it will only let you do so much. Join Photobucket upload your pix there then using the link post the pix here on DF.
Not the cause of a NO BUS. It's a plug for something you don't have, probably a front wheel speed sensor.
Unplug the crank sensor, cycle the key and see if the NO BUS goes away.[/QUOTE]
Im trying to find a crank sensor in the haynes manual but no luck. Is it the crankshaft position sensor?
Sorry about the broken quote command. Im still not used to this tablet...
Reason: broken command
