IAC valve bolt
Old Oct 26, 2013 | 01:00 PM
ataripirate's Avatar
ataripirate
Default IAC valve bolt
1997 Dodge Ram 1500 360, Automatic, 4X4, 130,000 miles
I replaced the IAC valve, I didn't think that I had the bolts out all the way, took off the wire clip and one of the bolts fell out and out of site, ran a magnet everywhere I could and looked everywhere I could see, but could not find it. I put the new valve in and put one bolt in it. It is halfway working, better then the old one, but there is a air leak around it.
so it is still dying when I drive it and let off the gas, just not quite as bad as it was.
Is there a place I can get a bolt, or does anyone know what size it is?
Any help would be appreciated.
thanks
Bobby
Old Oct 26, 2013 | 01:24 PM
merc225hp's Avatar
merc225hp
Best I can offer is the factory part number 05003467AA for now. Hopefully someone else can offer up the thread pitch, dia, mm or not and length. Make sure the O ring is on the new AIS or AIC and lube it a little before you install it so as it does not fold over or roll off.
Old Oct 26, 2013 | 01:35 PM
ataripirate
thanks, would the dealer have the bolt?
Old Oct 26, 2013 | 01:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Junk yard.
Old Oct 27, 2013 | 09:49 AM
ataripirate
Default Iac
ok,so I got a bolt and put the iac valve in. took it for a test run, went down the street a ways and back, did just fine. 10-15 minutes later, moved it over in the drive and gave it some gas, held it for a minute then let off and it died, started it back up and did the same thing and it died again. that was what it was doing before I replace the IAC. Is there something else that would cause it?
any idea?
thanks
Old Oct 27, 2013 | 10:20 AM
Bad TPS, dirty bore for the IAC, vacuum leak, low fuel pressure, etc.
